Om642 Air filters
matthew k
Winchester Hampshire
2005 320 cdi Sport 7 seat estate
Hi, I got these from CP4LESS for only £26, which for Mann filters I thought a good price. However, as you can see they lack the plastic frame that the OE and some other aftermarket filters have. How critical are they, should I send these back. Cheers
(Can anyone tell me how to produce the thread title in bold?)
malcolm E53 AMG
I always use MB or OEM parts wouldn’t use anything else not worth the risk of it either not fitting or damaging the engine
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Left side has the mesh. Looks to be some kind of turbulence device . Air flow ... fitting will be ok. The purpose I'm unsure...
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
I wouldn't too much about an air filter, but I would be concerned if it were an oil filter.
Completey laughable that people out of warranty buy overpriced genuine products thinking they are superior .
Wow... just wow
Have a chat with some of the indies on here and get their take on aftermarket parts and sensors...
Original parts don’t have to be overpriced. Quite often with a bit of negotiation you can get genuine parts (with a warranty that actually means something) for less than patern parts.
Original parts also fit without issue and they work as designed. Not copied.
If you can find the OEM then all well and good. If not I’d start with genuine and see what deals you can get.
EmilysDad
Bury Lancs
ML350
You're not going to damage an engine by using a pattern/copy air filter! ;)
Gazwould
C250 CDI
Find who the OEM's are and usually purchase the identical product cheaper .
M
matthew k
Er, just read through and then opened the other box.......feel a bit stupid now. Sorry and thanks at the same time!!! :)
onefortheroad
uk.
Ha ha . Class m8. Next time open boxes ...
onefortheroad
uk.
M
matthew k
  • #20
We should continue this thread. I often find that there is one tiny subtle difference between the dealer stuff and the OEM aftermarket products. I wonder if it's more to allow differentiation than for functional reasons. I also think strange things go on in the background, more than once have I seen a ECP van parked outside my local .. dealer.
