Gurkus
- Oct 29, 2020
- Chrysler 300c 2006 3.0crd
Hello, I have 2006 om642 3.0 diesel engine with 218hp, its fitted in Chrysler 300c, but its a mercedes engine, so i hoped that someone might help me there.
Issue started about 4 months ago, the old turbo went bad, no metal particles fell of, but inside of the turbo where the regularor pins and "valves" are, the ones that are moved by actuator went bad. Heavy black smoke, no power at all, car struggling to get to 30km\h, jerking, p0299 fault that there is not enough turbo pressure. I bought completely new turbo with new actuator, cost me 700eur, it accelerates now ok, but it still makes ton of black smoke, very dark black smoke, not blue. When engine warms up and i accelerate, at around 80km/h it goes limp mode and throws p0299 - low turbo pressure. Injectors have 35k km on them, still sent to testing, they all were just fine. All filters are changed. I changed the pressure sensor as well. Changed intake seal before turbo, changed all the seals of exhaust, tested the intercooler for leaks, its all good. But still the same thing - limp mode. Took out the egr valve, it seems fine, i had a working used one from the spare engine, swapped anyways, but nothing had changed. So i have no idea, what else could it be. Depeted dpf, so i expect it to have a bit of smoke, but now its so bad that i accelerate at the traffic lights and cars behind me just go invisible.
