Morning.
I have an E280 with the OM642 engine. It kangarood for the first time ever last week and when scanning showed 2510-1 and 2616-2 (actuator and back pressure sensor) The engine light didn't come on, but it went into limp mode. I restarted the car and all was fine.
The actuator has already been replaced with a rebuilt one some time before I bought the car.
I've got a replacement back pressure sensor on the way but I wanted to know if it is normal to be able to move the actuator arm up and down approx 10mm when the car is switched off?
The actuator moves with the ignition on, but I am wondering if the play in the linkage is normal or suggests the cogs inside may be worn?
Can anyone with the same engine check if theirs does the same, please?
Thanks!
Thanks!
