om646 strange noise. timing chain?
mbbbm
E200 cdi 2007
The car makes a clicking sound like a warm engine.
I have changed the multi-groove belt and rollers. But the sound is still heard. Is it the timing chain? do you have experience?
car is E200 cdi 2007 540000km
a couple of videos of the sound
M
mbbbm
E200 cdi 2007
  • #2
car is E200 cdi 2007 540000 kilometres
check to videos below.
Noise 1
Noise 2
ajlsl600
france
If noise does not go with belt off. Chances are chain. If need be go for chain tensioner first see wot sounds like after.
M80
Derbyshire
The duplex chain isn't a known problem on the 646.
Tbh I've not heard that the tensioner is either, but many know more than I.
Is the aux belt tensioner in good order?
As said take the aux belt off and see if the noise is still there.
ajlsl600
france
Tensioner 1st for noisy chain. O ring gets dry oil passes tensioner stops working as designed but take beltoff 1st n check
M
mbbbm
E200 cdi 2007
thanks for the answers. The sound is still there even after I removed the belt.
ajlsl600
france
Well. Not belt or associated pulleys then. Me I would try tensioner.
horatio
Herts
190E, CLK
There’s so much room to work on a 220 211… it shouldn’t be a huge job to replace the guides & tensioner (a pro can chime in here?). If this is the noise.
There’s a video about the merc duplex chains on YouTube (think it was on legit street cars), the bloke was saying they are basically indestructible and it’s better to keep the old
5w155t0ny
R230 SL350
I would say that isn't a tappet noise, but could be a worn pulley.
Doesn't really sound like a timing chain issue to me but that could be the sound quality on the video.
M
mbbbm
E200 cdi 2007
Thanks for the answers!
The problem was resolved! The sound came from the chain
jerzy
W639 115CDI 2004
Hello,
Was it fixed by the chain tensioner, or did you completely replaced the timing chain?
