markben
- Feb 12, 2017
- Location
- Bristol UK
- w220 2004 S320L CDI
Greetings all on this helpful forum
My now 140k mile 2004 S320L cdi performs well with plenty of smooth power, good fuel consumption (31-45 mpg UK imperial / 25-37 mpg US) & rarely needs the engine oil topped up. Never any DPF warning light or limp mode problems, always passes an MOT (Annual Inspection) with no emissions issues.
The car leads a gentle life with daily approx 10 mile trips around town and a monthly 150 mile run on faster roads. With plenty of torque at low revs from the 3.2 cdi engine, I rarely need to ‘stretch’ it beyond about 3000 rpm.
BUT.. ! I’ve noticed that it does chuck-out some exhaust smoke under hard acceleration when I occasionally get the revs up above 3000 rpm. Not black smoke, more light greyish. All the same, it’s a bit embarrassing when I leave a bit of a smokescreen for …. following me!
I’ve read that that the car’s engine management ECU (?) should ‘passively’ regenerate the DPF in normal use, but I’ve also read about professional DPF cleaning services for ‘forced regeneration’
My Question: is it better to clear the DPF soot with more regular long, fast drives or have the DPF professionally cleaned? Or by some other method, e.g. fuel additives? Or... simply leave it alone?
Since the car runs so well otherwise, I don’t want to fix the occasional smoking problem by creating several other ones!
Many thanks as always
MB
‘The Best or Nothing’
MB
