edext24
- Oct 7, 2024
- Mercedes C250 CDI 2011
Hello,
I have a Mercedes C250CDI from 2011 (OM651). About one month ago I had P0299 (low boost), P2279 (air intake leak) and P2463 (soot in DPF).
I performed a smoke test and figured that the issue was from a badly mounted intake manifold. I replaced the seals, re-installed the manifold, did the smoke test again and everything was perfectly sealed, no smoke coming from anywhere. The error codes disappeared for about 3 weeks.
Two days ago, engine light came up on the dash again, with a limp mode, with the same error codes mentioned above. I did the smoke test once again, and there are no leaks, even though I have those errors.
The first time, someone from MB told me that the problem was with the boost leak, and not the DPF, and that the DPF didn't show bad values. It was true then, because there was a massive leak at the intake manifold which got solved.
The soot now is at about 11g.
Cannot figure out what it could be, and I don't want to change 10 different things, spend a bunch of money and still not fix the issue.
Should also mention that a few days after I first fixed it, a fuel return hose cracked and spilled a lot of fuel on the engine until I got home to fix it. Removed the diesel fuel from the engine bay with a syringe and wiped it as best as I could, I'm mentioning this because maybe fuel got onto some sensors or something.
