Orthopaedic electric seat control
Marc Ellis
CLK c209 2006 220cdi
Hi everyone, I have reasonably bad back issues and I need to drive 60 miles each way for my commute to work (hopefully just for another 8 months) my new commuter is a clk c209 56reg 2.2 cdi with 7g autobox..... and it has orthopaedic driver and front passenger seats.... these are the ones controlled by 4 switches to the side of the seat pan closest the central console/armrest (photo to follow but sure you guys know what I am talking about). Here is the issue THEY DON'T WORK. Now the bottom on dash above the stereo to set down REAR headrest does not work either. I think I read somewhere that they are on the same circuit or control unit? Anyway clearly I want as much comfort as possible and I AM HOPING THIS IS NOT A COSTLY RESOLUTION but could you help me to fix/troubleshoot the faulty orthopaedic seats. Many thanks in advance.
McDonald
Surrey
SL500 2004
Hi Marc and welcome. Hope it's something simple, like a fuse. Someone with knowledge will be along shortly, I'm sure.
M80
Derbyshire
Aside from a dedicated fuse/s under the bonnet (as on mine) I can't offer any help.
As far as I'm aware though if the drivers seat can't be adjusted it'll fail the MOT. They've always tested my electric seats.
M
Marc Ellis
Thanks M80 but unfortunately you have completely mis understood. I have manual seat adjustment with orthopaedic control which is 4 bladders with in the seat that inflate or deflate to suit contours of user via these controls. I have attached a photo of said controls. I would of done of it of my car but away at the moment. Still hoping for someone's previous found solution. Many thanks.
  • Like
Reactions: M80
M
Marc Ellis
You legend Srdl! I wouldn't of picked up on that thread.... sounds as though it's a common issue to some manual labour called for if I had the time ... that said the thread "on the other side" (dark side?) Has photos which are only accessible as member. Is this a sister forum and login will apply or do I have to register there to access? All the best.
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Here are the two photos:
AB2E2CD1-3D71-4287-9B0D-660FE46707AF.jpeg A7487856-B351-4C06-8F77-D4C10F51C95A.jpeg
It is a separate registration for that forum but it’s not as good as this one!
Srdl
Hampshire
Just found two more at the end of the thread:
CD621717-FC34-46D9-B072-537F594CF6F4.jpeg 0D76F2D0-B66A-44CD-AD74-34F209B950BE.jpeg
You might have an air pipe off or the little compressor has failed
M
Marc Ellis
steve as i said you legend, thanks for uploading the photos here and I hope to put them to good use shortly, up against it on deadlines for work and 6 week old (3rd baby) might stop me from resolving this sooner! many thanks and ill report back.
This is always worth checking. Some cars when detecting a leak (r230 for example) will shutdown the pump to prevent the motor burning out.
