Outside temperature sensor clk 230
winston
i've been trying to locate the outside temperature sensor but can't seem to see it. I don't know what it looks like either, i was told its located in the bumper but as its my first mercedes i don't know where. i need to replace it so if anyone can help let me know.
Winston
IIRC below the bumper on the pax side, it is the little black thing not to get too technical ;-)
hmang
hey blobcat
educate a thicky (me that is)
what's this "IIRC" that i keep seeing...and keep not understanding
IIRC = If I Remember Correctly
If some of the TLAs (Three Letter Acronyms) are a little confusing them type them into Google and you should get the answer :)
W
winston
sensor
Thanks very much for that i'll check it out when i get home
Winston
Ellsy Tanners
Mars
It will be located in one of the small black plastic inserts in the bumper. Next to the fog light on the nearside i think. The insert is ruffly the same size as the fog light. it will look like a black pen tip pointing through the hole. hope that helps
