ovp relay where?
dandpl
South West France
1986 300sl left hand drive
Wher may i find the ovp relay?
Many thanks in advance,
You are all Mercedes stars!!!!!!!!!!!!!!!!
dandpl
If you can just hang on a bit we can tell you,the site that we use is down today so far.
Will post back ASAP
Malcolm
dandpl
dandpl
South West France
ovp relay
Malcolm
many thanks for that but where on the car is the unit located I can not find it under the hood
dandpl
its up front in the fuse box on the fire wall.
Malcolm
dandpl
dandpl
South West France
ovp where?
Malcolm
Dear Television ...............I must be thick I can see no sign of ovp in engine bay............this is an 86 left hand drive 300sl chassis numberwdb1070411A082785...........thanks for your patience!!!!!!!!!!!!!
dandpl
Myros
R107, S211, R170, C219
David
it might not have one. I looked and looked in mine, and it doesn't have one either. Some do, some don't.
dandpl
dandpl
South West France
ovp relay where
http://www.detali.ru/cat/oem_mb2.as...&L=765.707&CT=F&cat=574&SID=54&SGR=045&SGN=03
This is the only info that I have, Item 104 it is the one with the fuse on top and the only one with a fuse on top.
Malcolm
Dear Television
Thanks I think i have found it above the fuse box behind the passenger side kick panel above 2 other relays..........one of which is warm to the touch! whilst charging battery. Sadly the ovp seems a different part to the spare i have! Will let you know final result.
Ps Lyme bay is magic!
Dear Television
Hi David ,yes nic place to live.
Your OVP relay newer ones have 9 pins where as the older ones 7, i think that is correct to say.
You can test with a meter the inpuput is on pin 30 and the output any pins 87 and they shouls have 12 volt on them. Most of these relays go dry jointed and can be re flow soldered.
malcolm
dandpl
dandpl
South West France
ovp relay where
malcolm
Dear Television
Part number is 126 540 4745 ......was fitted with 5amp fuse so have changed to 10 amp..........this item has four metal pins and one plastic.........i will refit and see waht happens but also order another so i can be sure it function ok
thanks again
you are all mercedes stars
