P0410 Secondary Air Injection System Fault
adrian2313
I have a 2001 CLK230 Kompressor. After a long run up the motorway the engine fault light came on when waiting in a queue of traffic. The Fault code is P0410. The car appears to run as normal. I have had the fault erased and the light has not rel-it since.
Any ideas what it could have been?
Regards
Adrian
Adrian,,do look inside the MAF for any traces of oil, also the engine cam adjuster wires to see if they are oily
Ellsy Tanners
Mars
If that is the only trouble code, then the air system check valve is most likely blocked.
About £30 but can be tough to change?
A
adrian2313
P0410 fault
Thanks for all of your advice, i will check it out over the christmas hols
Merry Christmas
Regards Adrian
