rich.g.williams
- Oct 25, 2009
- Location
- Cardiff, South Wales
- C200 Kompressor Coupe 2003
- Thread Starter
- Thread starter
- #21
I put in a new electroplate today, all OK so far but not enough enthusiasm left over to plug the ETC computer back in and give the car a good run.
The hope is that the new electroplate will solve the problem but it just as likely may not.
Even the spurious outputs (and yes both gearbox speed sensors had similar spurious pulses) may be because the sensor is close to a transition so it flips back and forth, but then a well designed sensor would have enough hysteresis and it would not do it.
In theory it would be possible to generate two simulated speed signals to keep the ETC happy but it would create an enormous Safety concern. This gearbox can shift from 5th to 1st in two solenoid operations for a fault condition - avoiding this is probably the primary reason for the speed sensors and a primary concern for the ETC.
