steve gooding
- Jan 15, 2018
- 2012 C220 Sport CDI estate
Evening people, looking for a bit of advice please.
With the current lockdown I haven’t needed to use my car for the last 2 weeks. Today I started it, just to run it up, put a bit of charge in the battery etc. Anyway I lifted the bonnet while it was running and couldn’t help noticing what sounded like a vacuum leak coming from the inlet side if the engine. Obviously you can see absolutely nothing, so looked on net for anything similar. Cracked manifold is what I kept reading, but if this was the case you’d have boost escaping when the turbo spins up. So I took it for a drive, windows down but couldn’t hear any hissing that is consistent with a boost leak.
So I plugged in my cheap fault code reader and it logged the above code. P200A75 - intake air control actuator performance problem.
I have looked into this and other people who have this code get all kinds of running problems. Mine still runs fine, no smoke, no performance drop off, turbo still boosts, mpg still seems ok. I’m guessing it’s either the flaps on the inlet or the actuator motor itself. It doesn’t appear to be run off any vacuum, so I’m guessing the hiss i can hear is the flap stuck open?? Maybe, or am I barking up wrong tree completely?
While I don’t need the car it’s and ideal time to look at it, but not sure how to check if it’s the flaps sticking, or the motor not working. Or should I leave it until I get noticeable running problems? It looks like a right pain to get at.
Any tips appreciated.... thanks
Steve
Steve
