Oldspanners
- Oct 30, 2017
- Location
- Normandy
- C CLASS 2004 C180
I would have no certainty that the pedal is the problem but it is suspect and without a full session on Star it would be just a guess. I would remove the pedal and clean the connectors with electrical contact cleaner and see if that changes anything and then you have a chance of knowing you are in the right area but if the pedal itself is faulty it will need changed.Would you say the pedal is certainly the problem based on those readings with the engine turned off? What's the other likely causes? Tps? And pedal fir what they cost I can just repalce both. If there no chance if could be something else.
What would you suggest cleaning the connectors with? Thanks for all your help/ advice its greatly appreciated.
Steve at Avantgard would be the expert to consult.
