Park Tronic Intermitent fault
V6Matty
Newark, Nottinghamshire
Morning All
I know this has been brought up before but couldn't find any "how to's" on fixing the issue. It seems that either the front or back parktronic sensors occasionally go faulty (more often than not these days) I think its down to water getting on the connectors so want to check this before I go down the route of replacing sensors (I will have it put on star first though).
Any help would be great
I have a paper on this that you can have
V6Matty
V6Matty
That would be great Malcom, would you mind sending it to me,
OK you can edit out your address :D
V6Matty
V6Matty
thanks Malcom, looks great, shouldn't be to difficult to do :)
It has bounced back, the address is wrong
V6Matty
V6Matty
I was looking at it quickly as i'm at work, problem was I was looking at the load cover motor stuff you sent me the other day lol doah!
OK Matt sent again :D
V6Matty
V6Matty
got it this time and its definatly the right one, thanks again ;)
V6Matty
V6Matty
by any chance do you also have a paper on how to remove the trim on the front bumper where the sensors are housed
amb67
The Garden of England
Mercedes-Benz C220 Coupe AMG, E320 CDI (S211), Aprilia RSVR
Generally the PTS sensor that gets damaged through water ingress is the offside rear.... I had one that went faulty every time it rained heavily, replaced the sensor and all was well.
You can get the sensors on Ebay really cheap, just make sure it's a genuine one.
Takes under 5 minutes to change but be careful you don't break the plastic mounting on the bumper fixing.
machbuffet
Northern Ireland
E320cdi / 2006 / 3.0 V6
Hi V6 Matty and television.
I was wondering if either of you chaps could send me the papers on both the Parktronic and Load Cover issues.
Intermittent problems with both and any guidance much appreciated.
My email is boeingbbj@hotmail.com
Thanks in advance
Griphin
Manchester, UK
E320 CDI Avantgarde Estate / 2004 / 3.2L Diesel - Leyland National 2 /1984/ex BA/ 11.1L TD
Hi gents,
I was just wondering if V6Matty managed to get his parktronic issues sorted out. I recently bought a 2004 E320CDI Estate, and the hardest item to get my head around is the 'bl**dy' parktronic. Simply put I press the alarm silence button twice at which I get a beep and depending whether I have a forward or reverse selected, I get just 4 red lights and nothing else. However this is the case permanently so I believe it is not water related issues. I have done a visual check of the all the sensors and nothing seems out of place.
Would it be possible to get a copy of these instructions that you have so that I may do a more thorough check of the sensors. In some ways I wish the issue would be indicated on the dash. Nothing worse than a problem without an apparent cause.
Thank you in advance,
Richard
cheefie.d@gmail.com
