Parking brake - E320 CDI estate
Chesterchaucer
E320cdi
The parking brake (see pic) on my 2003 E320 CDI Auto estate (W210) has suddenly stopped working.
When I push down the foot brake pedal moves but it doesn't lock in place. What could be the issue, any ideas would be appreciated. Thank you
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Probably an issue in the mechanism above and behind the foot pedal.
C
Chesterchaucer
E320cdi
Thanks for the reply. The pedal goes down fine and pulls the two cables back - but it will not click in and hold like it used to. .
onefortheroad
uk.
Yes, I believe the ratchet mechanism is on the foot pedal assembly. It's mentioned elsewhere on these forums with pictures.
C
Chesterchaucer
E320cdi
Thanks,
You're right, it's the small spring behind the brake pedal that’s broken (see pic), but accessing it is a challenge unless you're a contortionist.
Does anyone know the part number or where I can get a replacement spring?
onefortheroad
uk.
Thanks,
If you enter your vin on the partsouq website mercedes section , you'll be able to view schematic drawings with part numbers. Hopefully the spring will be separate, if not you'll need a spring shop :) like eBay etc.
