Parking brake not releasing
Tony sirett
Worksop
2011 mercedes-benz e-class e220 cdi blueefficiency avantgarde auto
2011 E220 S212 cdi avantgarde
Yes, yet another problem has arisen, finished work this evening, started the car and put it in gear, pulled the park release handle and nothing happened, finally it released, any ideas what the problem is please? Park brake need adjusting? Sticky cable?
Thanks Tony
Handbrake shoes rusting on is a common problem with the handbrake on many cars.
rifiki
Worksop
CLK W209 W121190B
Hook the pedal up with your foot. Have been doing this for years in spite of regular maintenance.
Push the pedal down hard it usually releases.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Thanks Tony
Can you clarify if the shoes are sticking or simply the handbrake pedal that's sticking.
T
Tony sirett
Worksop
To be honest, at this moment in time I'm past caring, I have had nothing but trouble with this car, and to top it off I have come out this morning to find this underneath it.
mattkh
England
A160 W168 1999 1.6
When the oil was changed, was it by suction or sump plug removal. If the latter, then check the sump plug for a leak.
T
Tony sirett
Worksop
Was done via sump plug, new copper seal and bolt, torqued up to the correct ft lbs, have been underneath and the sump plug is dry.
onefortheroad
uk.
Check the oil filter housing ,was the rubber o ring installed properly. Was oil spilled filling it up ?
T
Tony sirett
Worksop
At mb mansfield now, not looking good, it has an oil leak on the inlet side or something plus lots and lots of other problems, I shall do a whole new post on it later.
00slk
Cambridgeshire UK
I feel for you, at least I'm not the only one with a 'hungry for parts' E Class :mad:
