Parking position for exterior passenger side mirror
Athar1
E220 CDI Coupe 2014
Hi.
I have followed the instructions in the owners manual to try and set my mirror to tilt when I put into reverse. When I manually adjust the mirror after putting into reverse, it just stays there when I put it back into drive. And if I reset the mirror, then it doesn’t do anything when I put the car in reverse. My car doesn’t have seat memory buttons. Anyone have an idea what’s going on?
here are the instructions I followed:
Park the vehicle and turn the key to position 2 in the ignition lock more.
Press button for the exterior mirror on the front-passenger side.
Engage reverse gear.
  • The exterior mirror on the front-passenger side moves to the preset parking position.
Use adjustment button to adjust the exterior mirror to a position that allows you to see the rear wheel and the kerb.
  • The parking position is stored.
V6Matty
Newark, Nottinghamshire
What car do you have?
If I remember correctly most older models if you don’t have memory seats the reverse mirror drop isn’t available
A
Athar1
E220 CDI Coupe 2014
It’s an E220 Cdi coupe 2014. Thanks
Srdl
New Forest, Hampshire
GLC43 AMG 2018 (X253)
Correct, you need to have memory seats for it to work.
A
Athar1
E220 CDI Coupe 2014
:( Ouch! Could’ve done with that feature. Thanks guys
Depends on the age, W213 dipped the mirrors without memory seats. Never had a W212 so couldn’t comment.
A
Athar1
E220 CDI Coupe 2014
It’s a C207. I’m just a bit baffled as it says it in the user manual.
Manuals are written for every possible option you could have had on the car. So if it had memory seats then they need to describe how the mirror can be made to drop.
Mujja
Bristol
C207 2016 E350
Hi.
I set mine after following this guide on Youtube. I do have memory seats though.
