Parktronic woes
bigtwin
Banned
Picked up my "new" 320 cdi today - a W210 X reg.
Parktronic doesn't come on with the ignition, and even when activated manually, the displays light up and the warning lights come up (outlines only) but there is no actual measuring feedback going on.
Planning on going back to the dealer tomorrow (some other faults too), but thought I'd ask if anyone has any ideas, just in case I'm missing something here?
Just asking the obvious, that you are parking with an obstical in range, and the shift in R or D.
malcolm
B
bigtwin
Banned
  • Banned
malcolm
Yup - tried it allways up. Simply registers nothing at all, even when you get to touching, front and back.
Shove it into R and the rear display in the roof comes to life, but does nothing else. Shove it in D and just the F does the same thing. Comes on for about a second, if that, when you first switch on, but then reverts to "off" - switch it on manually, and does as above, before switching off again.
Search here revealed several instances of the same problem, but no posted solutions. Car had full valet before pick-up, so no dirty sensors. Thought perhaps they may be wet, but been the same for all 10 hours I've owned it. Mrs BT absolutley spitting fur - not good :-(
Rory
Cheshire, UK
I was disappointed not to get Parktronic on my nearly new car but I since seem to have seen an awful lot of problems with it, once it gets to 2-3yrs old.
Did you buy the car from a dealer? The usually mentioned faults are either the sensors themselves or a broken wire - MB's Star Diagnose can tell which sensor is faulty.
B
bigtwin
Banned
  • Banned
Does seem to be a bit "luck of the draw" with them. And the dash electronics (although seemingly you can rest assured that there will be likely probs with that!)
Dealer, indep specialist, not main. Will be speaking this morn to them!
OK found somthing, parktronic is deactivated when the parking brake is applied. the contact switch of the footparking brake may respond with a significant delay=== replace switch
Malcolm
B
bigtwin
Banned
  • Banned
Malcolm
Many thanks - will check that. May be able to manually by-pass it to test.
acme8850
I have exactly the same problem with a 2000 320 CDI estate, did you ever cure the problem?
Regards
Vern
Regards
Vern
I think it must have, he has never posted back.
Malcolm
acme8850
Thanks Malcolm,
I will investigate the switch tommorrow.
Regards
Vern
acme8850
Checked out the parking brake switch and all seems OK there.
Problem still persisting.
Parktronic comes on lights up both front & back briefly, audio beep, but then switches itself off. does not sound when at close range, only initially when you turn it on manually. Then turns off.
Anyone have any ideas?
Regards
Vern
You cant check out the brake light, this has nothing to do with the brake light.
Like anything one cant guarantee a cure but for £9 it must be worth a go, it is a listed fault for your problem
whitenemesis
CLS55 AMG '05
Had Parktronic fitted works great. One problem was sensor failure signified by double beep and red segment displayed. Easily fixed by replacing one sensor (five min job). Sounds like you have Parktronic relay failure
A
A-GALLY
bad connection in the nearside boot, cleaned it wd 40 spray put it back as good as new
45375
N.Ireland
W208 CLK55 AMG and W201 2.5_16
Regards
Vern
My W208 CLK55 AMG had the same symptoms, popped into the dealer, quick test= Control Unit failure. New one ordered at £300 plus vat.
