Jasandjules
- Nov 8, 2017
- C300 Estate (s205)
Has anyone done this to say an E Class? If so, did it actually either improve performance or fuel economy?
Sadly the 2.0 Diesel in the E220 Cabrio...... 2018 Model.Which engine?
Yes I’ve mapped both my e-class’s and with the current one plan to do more
Still perfectly possible to map the for performance, it won’t be massive gains but will make it a little cleaner in the way it delivers it to the roadSadly the 2.0 Diesel in the E220 Cabrio...... 2018 Model.
My view, if you want more power buy a bigger engine, in this case IL6/V6. More power equals more heat dissipating that heat across more cylinders prolongs engine life. Both my cars, IL6 and V6 are rated at no more than 50bhp per cylinder which is under stressed for a modern ICEI not a fan, offered that at egr and adblue delete. Declined any map increasing performance outside stock, will in my view have an effect on long term reliability makers maps are max efficiency, max mpg at max longivity, reliability.
Sure all won't share this view. but sticking wid dat on. My motors.
