Perished parking bulb sockets
StephenMF
Preston
2009 C220 Blueefficiency SE CDI
Went to change the bulb in my 2009 C220 after dashboard alert, only to find the yellow bulb socket has seemingly burned out at some point and part of the plastic housing, as pictured above, broken loose and just placed back behind the bulb cover.
Double checked the other side and the same thing has happened there!
Has this happened to anyone else here?
Car is under dealer warranty as only just bought last week so will be going to get fixed but wondered if this Is likely to be a full headlight change or if there’s an easy fix
Looks like a new bulb holder required. Can't see any damage to the headlight from that pic.
Simple enough if it is.
wahfu
Gold Coast, Queensland, Australia
W210/E320
Had a similar thing in my year 2000 W210/E320. Fitted with Xenon lamps by MB factory but heat or UV must be so intense that parking bulb holders and general wiring inside the headlight module was badly deteriorated requiring professional repair.
star
Reading
Smart + others :)
It looks like the bulb holder has got hot and stuck itself to the headlamp and has been snapped off in trying to remove it. Seen it before.
StephenMF
StephenMF
Preston
Yes, that’s what the dealer said when they had it checked but won’t fix as the bulbs are working safely and it’s age related wear and tear!!
star
Reading
Smart + others :)
Plastic and heat don’t go well together.
StephenMF
StephenMF
Preston
Indeed, and it certainly seems to get pretty hot in this car’s engine bay
star
Reading
Smart + others :)
It’s the heat from the bulb that “welds” them together. :(
