persistant ABS problem - 190E 2.6
Status
Not open for further replies.
David Halsey
I have a 190E 2.6, which is my pride and joy. But, the nearside ABS sensor keeps failing. During the last two months it has knocked out 3 sensors (not cheap!!). This then causes the ASD to go haywire.
Any advice would be welcome
Andy
West Midlands
www.mercedesservicing.com
Hullo Mr German & Swedish
The routing of the ABS sensor is critical, as the wheel turns the brading( think of the sensor as a long aerial extension cable, with inner & outer brading.) This can crack the cabling causing the light to come on. Also check the wheel hub. This can cause a number of problems. Having changed a number of ABS sensors, I would look at the hub.  A compatent technician should be able to check the AC out put of the sensor. To identify any problems.
As for your ASD. This system was never one of MB best ideas?
Hope all goes well. You can contact me on... (Yes you've guessed it) www.mercedesservicing.com
Regards
Andy
Anonymous
Hello David,
Learning that you have the 2.6 190, I am envious,I had a 92 model that was lowered & AMG wheels.It was a superb car,in every respect & as sure footed as a cat.It was 100k when I (gave) part exchanged it for a C classs
& it was still as smooth as silk.I regret parting with it very much indeed.Many have completed prodigous mileages without any major problems whatsoever. It is recognised as being the definitive 190 model & in my opinion a classic car of the future.What ever you do, dont consider a C !
regards
Ernest
Status
Tel: 020 8863 9233
