brianbrian
- Sep 27, 2008
- Age
- 82
- Location
- cockney in the West Country
- w124 250D, SL129-deisel
Hi Chaps, As you know i am trying to fit a 1990 diesel (124 model)engine & gearbox into a 1992 sl 300 24v, can not use g/box from the diesel as it has flexi drive for the speedo, sl is electronic, also found out speedo would not have given true reading, tried fitting speedo from diesel into sl instrument panel, but would have to drill hole through sl printed circuit, for flexi drive. So am using sl g/box,,have taken flywheel of diesel engine,and had it machined, so torque converter from sl will fit, got it backToday perfect can now fit diesel engine to sl gearbox, had lots of help with how to fit vacuum pipes.
Will keep you all informed of progress
brian
p.s. i have 4 speed automatic gearbox from 1990 250d (124) for sale
the sl engine has already been spoken for
brian
