- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
Valeo have been developing a new engine with no running gear, that is no timing chain or camshafts.
The valves are operated by solenoids controlled by the engine ECU, this means that that valves are open longer and quicker allowing up to 7 injection per cycle. This is used in conjunction with new injection systems that run at 1700 bar, almost the same as diesels. At this pressure the fuel is atomized to its max. This used with generation 3 piezoelectric injectors where they fire under pressure as the piezo is right in the tip of the injector adding to the up to 7 injections per cycle.
The third thing is doing away with the manifold as we know it, there will be no vacuum at all,just like diesels and the special flaps will control the direction of the fuel. the normal ratio of air / fuel is 14:1 with this new system the flaps can change the ratio when cruising light throttle say 50 mph and upwards, the flaps can make the fuel air to sit right at the top of the bore, this will enable the car to run on a air / ratio of 40.1 as against the 14;1 that we use today.
Well this is all I can say for the time being,,I got this info from the last mechanEX held in London this week. I could not write it all down and the lecture was all on slides, and it is as near as I can remember. Any future updats I will post
