petrol vito, running rough at low revs
st nigel
please help,,,,
petrol vito done loads of miles, plenty power, does not burn oil etc....
runs rough at low revs,,,ticking over ok- then revs build up- then starts running on 2 cyls then- flat spot when pulling away,,,all these faults intermitent and appeares not to happen when on choke,,,
Also is it worth converting to a deisel or what other vehicles have the same petrol engine as my 113,,please help....
philsparky
hi st nigel, have a petrol vito [a v class 230] with similar syptoms to you luckily i happen to be an mb auto electrician which helps! to remedy the problem i have replaced the lambda/oxygen sensor & it has run perfectly well ever since you dont need to buy it from mb either mine cost £40 not £105 + vat from my local parts supplier and was a 4 wire universal one,good luck.
st nigel
thanks philsparky
thanks for reply, much apprechiated...Does it still sound like the lambada sensor if so how sure are you??
a few things have changed,,found a fractured vacuum pipe from a component??? behind o/s headlight that runs to the inlet manifold, made a good temp repair, now not so erratic when ticking over,,but still has a very bad flat spot causing it nearly to cut out giving a cough and splutter when pulling away,,,
New probs occured immediaetly after repairing the vacum pipe,,a horrible cat smell and signs of black smoke and condensation from the exhaust?..nigel
