Phantom (but appreciated) Google Maps Audio appeared via Viseeo mb4
MuckMouth
2005 CLK 320cdi
Hello everyone, this is a long, boring and most likely fruitless question - but it has been annoying me, and hopefully someone can help, or at least put my mind at ease. Oh, and I know older Merc's bluetooth compatibility (or lack thereof), in particular for music streaming from a phone - has been discussed to death, but I cannot find much on this particular issue.
Ok, so it is a 2 part question really and here is the background info... I have a Viseeo mb4 plugged in to my 2005 CLK (which has the COMAND unit with Freeview Tv/NAV options etc.) - and for making phonecalls it is crystal clear and works a dream, and usually for music I use an FM transmitter (as I like to be able to switch songs easily), but yesterday the FM transmitter was not plugged in, and something weird happened - Google maps audio came through the speakers - and politely interrupted the radio station I was listening to when necessary to tell me to turn etc., this is something that has never happened before - and only worked with the FM transmitter.
After I got home, it was bugging me as I couldn't work out how/why this had happened. On top of that, I then had the idea to try linking my Spotify with my Google Maps, and then streaming music through the Maps app... genius! Or so I thought, as next time I tried I couldn't get Google Maps to play through the speakers - APART from for a split second before and after a phonecall (and during this split-second my music through Google trick DID actually work on each attempt I tried)... So with all that in mind:
1/ is there a setting in the phone/app/viseeo/car/anywhere that allows Google Maps to play through the speakers (I have toggled on 'play voice over bluetooth' and 'play as bluetooth phonecall' in Google Maps settings - which both seem pretty tailor-made for my needs)? Or did I just experience a weird glitch in the Matrix and this Google audio phenomenon is likely not to happen again?
2/ if there is a way to do the above, should the Spotify-via-Google-Maps option work in theory? (remembering that it DOES work for a second before and after a call)
Huge apologies if this all too nerdy/boring/specific, but it's kind of interesting and I think there simply MUST be a way to make it work (without having to use the FM transmitter, that does actually do what it is meant to, but not only looks a bit dated/ugly but also experiences slight feedback/interference that I have never been able to get to the bottom of either).
Stafford71
W208 320 Elegance
Hi, quick assumption.
Is google maps from your phone, if so
volume up or down on your phone
At top of volume level there is a phone looking icon, press that, should take you to media output.
Set output from speaker to.paired device, should be good.
Hope that helps
Sent from my ONEPLUS A6003 using Tapatalk
Botus
S500/2010/500
…. is there other equipment in the car?
a viseeo MB-4 can ONLY BT phone calls via the UHI socket in Mono sound.
what phone? I forget but on a different car using google spyware incl android I think it can play SAT NAV instructions as a phone call,
they will do ANYTHING to get your contacts and destinations back to their servers (so they can sell your life - so I wouldn't be surprised). The only surprise should be how society became so weak and corrupt that there are so many low moral filth, prepared to work for them and enslave themselves…
no morals and really dim to boot ???
