kanehug
- Nov 30, 2019
- Location
- liverpool
- mercedes c270 2004
hi guys, as you can probably guess from the title , I need to change the plastic fuel hoses that lead from the valve to filter in my c270.
ive ordered the new one but its not going to get here until early jan due to xmas post.
my question is, Could I use fuel injector pipe (rubber hose) with the existing fitting as a go between so im not with out a car over xmas ? euro car parts sells a metre for a tenner apparently designed for high pressure injector lines , so I cant see a reason it wont work as a temp fix , was wondering if anyone else has done anything similar and how successful they where ?
thanks in advance guys im in a sticky spot !!
https://www.eurocarparts.com/injector-pipe
the above link is what im referring to.
