mr rosher
thanks guys for all the help in the past, much appreciated, my e280 19993 is now running 98.9 %, but she still idles slightly to low when in D - R, in P _ N
idles at 750 rpm fine, as soon as she goes in D _ R the rpm drops to 550 - 600 and she starts to hesitates, this is the work i've done over the last year,
head, skimmed, decoked, new valves, seals, pressure tested,
new air mass,
new coolant temp sender,
new injecter seals,
head gasket,
new o v p relay,
rebuilt wiring loome,
inlet cam shaft renewed as mine snaped on head refit,
charcoal canister checked by local dealer,
trottle body changed, and cleaned,
new gear box oil a filter
egr valve cleaned and checked,
and eventually complete engine rebuild, as the bigends went ? when she overheated,
cost so far £1,890, most of the work has been done by myself,
she's been back on the road in the last 2 weeks and still running in, so far done 800 miles, i've been told of a switch or relay that increases the rpm by 50 rpm when in drive, or may be the pressure control cable is set wrong, i've cleaned all the relays, and fuses, but can't find the relay or switch that changes the idle when in drive, phoned the local mercedes dealers and asked but won't say ?? i've also been told that when key is turned on, there should be 2.5 -5. volts on one of the pins for the air mass plug, mine has nothing,
any help would be much appreciated as i am at a loss ,
many thanks rod
new air mass,
new injecter seals,
head gasket,
new o v p relay,
many thanks rod
