Hi.
Having a problem with my 2000 (new shape) C220 CDI Auto Saloon.
Drove it to Spain on Friday and Saturday - Motorway driving all the way.
It was fine when we left UK, but just as we got to Paris we lost a lot of power.
Pulled into a service station where I noticed that the engine would not rev beyond 3000rpm.
Turned the engine off and then back on again and the problem cleared with the engine revving beyond 3000rpm and the hint of a whistle from the turbo.
Once i put the car into gear and pulled off, once again, it would not rev beyond 3000rpm.
It is also really quite noisy (clattery and exhaust-boomy) at low speed in town or at the lights etc...
This pattern repeats and hasn't got any worse or better:
When stationary in park or neutral, will rev beyond 3000 rpm with turbo.
Pull off gently and engine stutters and kangaroos at around 2,500rpm blowing some (but not billowing) smoke; Pull off with foot to the floor and it pulls off from start cleanly but very slowly to 3000rpm in each gear, although you do have to shift the auto box manually.
Turn engine off and back on again and once again engine revs in neutral or park normally and turbo APPEARS to be functioning.....but is it really???
Called a very nice man at Mercedes Leicester as soon as the problem arose who wasn't sure what it was but was sure as long as no warning messages were appearing and that water and oil level and temperature were correct, it would be safe to continue.
We did and made it to Spain yesterday afternoon (with an interesting trip over the Pyranees given the 3000rpm limit!)
One thing I noticed this morning is that with the bonnet up and the car in park if you rev it gently up the range, at 2,500rpm the engine stutters and you get a puff of diesel smoke from the area to the right hand side of the engine (if you are sitting behind the wheel). It will climb beyond that point and, indeed, beyond that 3,000rpm limit as long as the car is stationary and in Park or Neutral.
Could this all be down to gas escaping before it gets to the turbo? Could it be simply down to a hole in the exhaust? Have I "done" my turbo?!?!?
Any suggestions greatly appreciated!
Thanks in advance.
Simon
Thanks in advance.
Simon
