Please help id this noise.
Deutcha
Hi all, I am having trouble (new car) knowing wether this is normal. Can anyone advise? EDIT: Am trying to sort link will have to re-post.
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Doesnt sound normal to me, can you identify which area of the engine the noise is coming from, ie front, back, middle, top etc. A model and year might also help. Can you see the tensioner pulley on the belt?, is it hopping about?
Mike
D
Deutcha
1998 E300 turbo diesel 152k never missed a service almost one owner from new, specialist maintained with genuine parts only, it's a minter. The noise is from the inlet manifold area (middle top). Smooths out with revs.
Parrot of Doom
Manchester
I think you need to remove the black engine cover and look again.
colechelle
Resigned
damper on the fan belt adjuster make a awful noise on them, put a screwdriver behind it while running, see if it goes!!
dougjoy
Canterbury
Mercedes Benz S320CDI
The engine sounds perfect to me except for the usual top end rattle usually from the hydraulic cam followers. Try mobile 1 0W-40 protection formula oil, it fixed it for me.
D
Deutcha
So just to confirm: are we going with noisy cam followers?
dougjoy
Canterbury
The oil is expensive but I think worth it, winns injector cleaner is only a few pounds, might be worth trying it first. I use it every 5K miles now and it does make a difference in performance and engine smoothness.
But your engine sounds good especially with the mileage, sounds as good as mine. Have you listened to another 300TD?
D
Deutcha
No Dougjoy I haven't. If you listen to the first clip it starts off slightly intermittent, this also true of the second clip. Would this indicate cam follower- sounds probable. Do you have sound clip to compare? It would be most appreciated.
dougjoy
Canterbury
I would not know where to start with recording and sending.
Sorry
