Zarniwoop
- Apr 8, 2022
- 2002 CLK 270 CDI (W209)
Hi all,
Apologies for the urgency of the title, but I really want to take my new car away on holiday on Monday, so I'm panicking slightly!
The car is a 2002 CLK (W209), and I spent this evening removing the door card, speaker and door lock in order to replace the lock spring and solve the bouncing lock problem.
I disconnected the battery to do the job, but reconnected with the door card still removed in order to check that everything was working. First I tried putting the window all the way down and then all the way up again. And then I tried locking the car and was delighted to find that this door lock now works perfectly.
GREAT... except that the window wasn't going all the way up to the top. It was stopping at its slightly-dropped position for opening and closing the door.
If anyone can shed any light on this I'd be amazingly grateful. I'm theorising that I've somehow done something that means the car no longer knows that the door is closed.
My questions are...
(1) Is there any chance that this is just the result of disconnecting the battery, and that it can be 'reset' or some such thing?
(2) If not, any idea what I've done, and if it can be fixed?
(3) Should I just order a new door lock and be done with it?
Really hoping that someone more knowledgeable than me reads this!
Thanks,
Martin
My questions are...
Thanks,
Martin
