PLEASE HELP WITH SERVICE AND PURCHASE DECISION
farshschafer
New Registration
C200
HI GUYS , I WAS ABOUT TO BUY A USED C200 2015 MODEL SO I DECIDED TO TAKE COMPREHENSIVE TEST TO CHECK VEHICLE PROBLEMS.BASED ON THE REPORT PLEASE HELP ME OUT TO MAKE DECISION TO BUY THIS CAR.
MINOR ENGINE OIL LEAK
ESP(Electronic Stability program -- ( 3 )
U0417FA
Data received from the Electric Parking Brake (EPB) were implausible.
B23AA1D Stored Event
The left brake calliper is faulty. The current value is out of the permissible range.
Stored
C100B77
The Electric Parking Brake (EPB) is faulty. The commanded position cannot be achieved. Stored Event
ISM(Shift module) -( 2)
P179A12
The Direct Select redundancy system is faulty. There is a short circuit to battery(+).
Pl 79DOO
Stored Event
The Direct Select redundancy system was activated.
Stored Event
PSD(Control module for panoramic sliding sunroof) -(1 )
U016887
Stored Event
Communication with the Electronic Ignition Switch (EIS/EZS) is faulty. The message is lost.
Noddy 99
Telford, Shropshire
2009 W211 E-Class E280 Sport Estate (OM642 3-litre diesel V6), 3x remapped, now returned to stock
Ideally, you need to use Autel to CLEAR the fault codes then run it again. "Historic" codes should not reappear so you will be left just with the current ones. That will sharpen the picture.
Whereabouts are you? It may be that someone on the forum will run a scan for you for the price of a pint (or less). I'm in Telford and have icarsoft MB II, if that's of any help...
