POI import to command
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Yes, I use it on mine NTG5*2. Do check their website because they will tell you what does and doesn’t work with your particular version of Comand - looking at your profile, W205 should also be NTG5*2 so you should be fine.
Works very well with mine and only 9.95€ a year iirc. The only problem I had was selecting the multiple items I wanted to download (UK and France) which needed different keystrokes on my MacBook but very happy to recommend them.
B
bc100
South Devon
S205 C250 BluTec Estate 2014. Sadly deceased due to flooding
I downloaded four European countries and I can see my local speed cameras. Haven't done a drive yet to test the audible alerts but so far so good. The cost is still €9.95 a year which seems reasonable.
Their email said that the NTG number in the drop down menu is not critical as long as I was able to see the test file.
jimbg
E Class Estate 2020 220d Prem Plus
Because it is a POI, does that mean you get an alert even if it on the other side of the road from the direction you are travelling?
That was the big downside when I have used these databases in the past, sometimes you would be on a parallel road and an alert would sound as you were within the warning "circle" around the POI!
richlumb
GLC 350d
Use it regularly but will only work with certain sd cards, it can take a few mins to upload onto the comand the first time
Srdl
Hampshire
Yes, it’s something I put up with. The M6 toll is particularly bad because you get a lot of alerts from nearby roads. It only takes a moment to look at the screen to check whether the alert is relevant or not - it’s better than no alert!
richlumb
GLC 350d
I’ve muted the alerts and just watch the gold alert circles on the sat nav as I usually have the sat nav screen as the main display there literally thousands of cameras around here so it never stops beeping
B
bc100
South Devon
I had a similar problem with Tom-Tom endlessly telling me about schools that were on parallel roads, however I'd rather know about the "danger zones" coming up, but I may try the richlumb approach. There aren't too many cameras around here and of course I never speed anyway!
