Underdash on the passenger side. Remove the screws which hold up panel up, and then its there in the airbox, rectangular cover with two slide clips to hold it all together.
Make sure the new filter is fully pushed home or the cover will be tricky to refit. If you have trouble take filter out and reinsert as it maybe miss alingned.
