psmart
- Feb 7, 2006
Unfortunately not, I found a lot out about the MAF characteristics plugged into CarSoft whilst driving to diagnose a gearbox problem through trial and error (as CarSoft showed no useable data regarding the MAF). I had the MAF disconnected and the fuel consumption rose, power was down, albeit Torque was similar, which I found interesting as I would have assumed that no MAF would mean lower torque to protect the gearbox.psmart, thats interesting. If there is a problem with the MAF, is that something that you will find out if you connect the car to a computer. Don't want to spend for new MAF if it dosen't do anything...
I have new air filter in mine so it will be the MAF, Injectors (hope not as it is really expensive), intercooler or choked up exhaust ( How do I find out?)
It should show me better MPG than 35 to 41 as 41 as max for long range, highway driving on 56 - 60 mph all the time.
When I changed the MAF on the ML there was a difference, especially as I drive at high speeds over 260miles each weekend, I noticed the tank not dropping as quickly (no computer in the ML, you had to use tank-tank checking). On another fault, I drove with the Turbo disabled and got just short of 40mpg (~39mpg) over 800miles driving around 50-60.
After changing the Turbo and cleaned out the intercooler and all associated pipes a lot of gunge came out of the intercooler (the engine crankcase breather vents into the air stream before the intercooler), difficult to know if the gunge was lodged in a place preventing air-air cooling, but sounds logical.
