Yes Star will only show fault codes that are stored, its still up to the mechanic to diagnose.Hi
Thanks for your reply.
Are you saying no to the fact that the a Star diagnostlc will not show the reason for high mpg. As I told the garage mechanic the problem it it was him that stated a diagnostic would show the problem. I do not want tp be paying out £150 for the test and it not show why the mpg is so high.
I did a 10 mile run and my OBD Scanner said I had used point 97 of a gallon.
Not really no.!
Do you have black smoke?
Any black smoke under acceleration? What type of driving?
These OM612's dont' have O2 sensors and only use the maf for very rudimentary confirmation that the EGR is working, it's not used for fuelling.If it's maf or oxygen sensor related , it will show on star , in live data . Have you checked all the fuel pipes for leaks and also the fuel tank and pipes . Sounds to me one of your injector return pipes or fuel filter pipes is leaking with the engine running.
Get onto a dual carriageway or motorway , reset the dash mpg thingy then drive for 15-20 mins at 60-70 mpg , what sort of reading do you get then .No smoke whatsoever from the exhaust driving steady down country road then 2 miles on dual carridge way.
HiIf it's maf or oxygen sensor related , it will show on star , in live data . Have you checked all the fuel pipes for leaks and also the fuel tank and pipes . Sounds to me one of your injector return pipes or fuel filter pipes is leaking with the engine running.
Thank you for the reply and information. On Tuesday I will driving 30 miles to the Mercedes garage which will entail 70mph dual carriageway and then single road with 50mph speed limits. I will see what the Elm OBD11 says after journey.
As suggested I will get them to check for leaks before using the Star Diagnostic.
I will post an update after garage visit on Tuesday.
I live near Gantham South LincconsireOP, whereabouts are you
We may be able to recommend a good fairly local indi
A 2005 car will not benefit from going to a main dealer ( if that is who the garage is you refer to - only they charge £150 to plug STAR in!)
