Dan the Man
Hi, was just looking for a few pointers before I get involved with taking the car to bits. I have a 1985 carburated 200 T W123, 105 K. Until this morning it seemed to run fine but is now idling low and appeared to have a missfire at low RPM in traffic.
It has had another curious problem in that although running sweetly, there seemed to be excessive engine movement, allowing the exhaust to knock slightly and giving the feel of poor running when sitting at lights idling. It sounded fine when you lift the bonnet, but engine movement evident.
I'm thinking the two problems may be related and a part is about to pack up somewhere. The car has had a major service including new ignition parts from a main dealer. Engine mounts have been done in the last 18 months. It was also hooked up to some merc diagnostic kit in the summer because I was curious about the engine movement. Nothing undue showed up.
Anyone have any ideas? I thought about a valve on the way out so will do a compression check at the weekend, but have no other thoughts at the moment...
Any assistance would be welcome!
