Hello all
I have a 5 year old 203 c class 270cdi 40.000miles-sport suspension. Last year I had an issue with the car which went into Mercedes and came out with the steering wheel slightly mis aligned, rather than book it in again I took the car to a tyre fitting company and asked for the steering wheel to be realigned, I stated I did not want anything else touched just the wheel aligned this they did along with altering all my rear suspension and god knows what else, the so called technician told me he had used some sort of guage on the car as well as laser equipment for what reason I do not know needless to say the car was absolutely awful to drive from that day on, I do not know if anything was touched on the front end except the tracking to align the steering wheel. I took the car back and told the technician to put it right, this he did not by reverting back to its original setting but by altering it still further stating he had put everything within manufacturers tolerances. Due to unforseen circumstances I have been unable to attend to this problem until now however the car has gone into Merecedes and had 2 new front lower arm bushes replaced due to perished rubbers and oil leakage and 2 new rear springs due to one possibly broken as it was making a bong type of noise from the rear end, the car has come out of Merecedes and drives better except moves from side to side mainly at lower speeds like constantly running over speed bumps or as somone has said like being buffeted by the wind, plus if I run over a drain cover the car skips on the rear end. The car tends to find every bump in the road, it kind of reminds me of an old Citroen I had years ago with adjustable suspension which when raised would bounce along the road. I have not told Merecedes what the tyre company have done but feel I should.
My questions are, do you think this could be unrelated to what has been adjusted, could this be a shock absorber fault or bushes?. Could anyone tell me if the rear end is adjusted would this alter the tension of the moving parts on the suspension or indeed alter the handling? Can the front suspension ride height be altered? Do you think I should let Mercedes look at it or go back to the tyre fitting company and let them sort it out! Would it be possible to put the car suspension back to factory settings?
Tyres have 5mm tread on front and 4mm on the rear
I hope you can understand what I am talkng about and await any reply's with eager anticipation as I do not know which way to go
Many thanks
Bryan
Many thanks
Bryan
