horatio
Long shot but is it possible to replace the ball joint separate from the lower front control arm (“cross strut”) on a 203/209?
I know it’s replaced as a whole arm but an annoying situation here. Car failed mot due to “excessive play” in said ball joint. They replaced the arm and did full alignment.
They’ve obviously fitted a cheap nasty arm and it’s creaking already. I replaced all the front arms with lemforders a few years ago, a pothole must have finished damaged it rather than general wear.
CBA going through the hassle of replacing the arm again and having the alignment done yet again…
Plus WiM are gone and this mot garage is the only other place I know of who can do a reasonable alignment so I’m not going to argue it. If they agree to fix they would probably just screw it up again anyway.
Cheers!
Cheers!
