Power steering flush.
DMK/Happy
SE / Coupe / 2003 / C 220/CDI/A
Hi folks! Diagnostics and service center when I was in at the weekend mentioned power steering flush and new fluid, any thoughts on this?
Oldspanners
Normandy
C CLASS 2004 C180
Good idea if it hasn't been done in many years or 10's thousands of miles. I did mine a while back used a large syringe, sucked out as much as I could from the reservoir, topped up with fresh fluid, moved the steering from lock to lock a few times and repeated until the fluid was the same colour as new.
Did notice any difference but was easy enough and another job done.
mattkh
England
A160 W168 1999 1.6
.......I did mine a while back used a large syringe, sucked out as much as I could from the reservoir, topped up with fresh fluid, moved the steering from lock to lock a few times and repeated until the fluid was the same colour as new.
Did you notice any differnce in the steering or noise?
mioba
Nottingham and Köln
Whats your mileage.
Get it done if your around 75k miles.
Easy enough to do yourself if you are handy and have the space.
Summary; Use a turkey baster to empty tank. remove and seal return. fill tank. suck from return pipe till it runs clear (turning lock to lock). put return back on and check level.
Botus
S500/2010/500
(pots 2006) buy a 1 ltr bottle of the correct straw coloured stuff merc use...
use a clean syringe, empty reservoir as best u can, refill. start car wind just sort of lock to lock twice, rinse repeat.... till the whole bottle's gone and the level is correct. 20 mins work £15 quid all done
do it as often at the transfluid
DMK/Happy
DMK/Happy
Hi all! I got the steering flush done at the service center,flushed through and cleaned with new fluid and conditioner added,the old fluid was discoloured,yellowish,probably a long time in there it seemed.Thought it better have it changed because the C220 engine weight is fairly heavy on the front wheels as C220 owners understand.Thanks for all the interest,appreciated.
Gazwould
C250 CDI
Is Mercs version of CHF11S really straw coloured ?
Botus
S500/2010/500
yes
the commons stuff is not the same as each manu spec. the one you list makes the steering heavy on Ford Focus Mk2, swap back to the ford stuff and its much lighter
and that's another round of confusion, Red PAS (aka std auto box fluid) is susceptible to over heating and falling to bits and often needed an oil cooler.... as the world moved, in 2005 the law said manu have to be responsible at end of life. So many manu ditched red and went with various hydraulic fluids that are more temp stable can have smaller reservoirs and no oil cooler (cheap / less enviro mess at end of life)
depending upon which factory built it, all Focus Mk2 were supposed to have green PAS fluid, but some factories used up old stock and filled many with Red..... Same on Alfa except on Alfa seems the seals fail - fords don't care
Gazwould
C250 CDI
When new and not coming out ?
DMK/Happy
DMK/Happy
MPM50001MB along with BG -PN - 330E conditioner filled to power steering after flush completed at diagnostic service center,they did everything according to MB specs,worth it in my book.
