power steering pump pully
tanraj
mercedes e270cdi
hi guys,,,i just had my car serviced from my usual trusted indie and been advised that my-
" power steering pully pump ,broken /damaging belt"
i have a e270cdi{2003-diesel}..
my questiom is, can this pump be repaired and do i have to purchase complete set,i mean can i buy just the pully.
after spending a lot of money this week on, ball joints and arms and servicing and tyres..
i simply cannot afford to spend any further money on the car till next payday..{4 weeks away}
are these,units expensive and how much can i expect to be charged for labour for replacing this.
thanks for any advice...
raj
cleverdicky
MB
The pulley can be removed and it can be replaced. But MB wont sell you one.
Depends on type / model but generally no unless you can get a spare or knackered pump and take the pulley off.
It needs to be pulled off with a special puller (like a bearing puller) and again carefully pressed on. But it can be done - if you can get a spare. Might be easier to replace the pump complete though.
It is listed as a spare though that is not always the case
This is it for the 647/6
050 A 6112300115 PULLEY,
Power steering pump
index.php
T
tanraj
mercedes e270cdi
thanks for your helpful replies....local MB dealer have a pully in stock for approx.£18 and i have also been recommended to also buy the pully belt for £57.00{thought that was a bit excessive}..suppose ,overall cheaper than buying the complete pump.......
cleverdicky
MB
Definitely. Lucky you have one that is replaceable.
I did check on ebay and cheapest pump (to take one off) was around a hundred £££
You can see in the pic I put up the ones where you can and the ones where you cannot ;)
cleverdicky
MB
I guess it's 'Sod's law' who gets what !!!
The answer is to study the EPC and WIS, read it all then buy a car that is the easiest and cheapest to work on.:rolleyes:
cleverdicky
MB
And that would be .....
One of these
Tel: 020 8863 9233
