Power steering
Dave54
ML270 CDI AUTO 2003
Not long had my 2003 mercedes Cdi auto and now the power steering has packed up. I have checked the fluid and that is fine.
Can anyone point me in the right direction.
Also I have no warning lights on my dash.
Uncle Benz
West Sussex
Mainly Mercedes
I’d suspect pump failure, but it isn’t a straightforward diagnosis. Get someone to turn the steering with the engine running while you look in the top of the reservoir for fluid movement
D
Dave54
ML270 CDI AUTO 2003
Cheers for the info
joderest
ML270 2003
unlike most, its quite a simple system, pump driven by belt, which powers the rack.
Have you got any drastic oil leaks ?
D
Dave54
ML270 CDI AUTO 2003
I found pipe off so all fluid drained out but now the pump is making an extremely loud noise
joderest
ML270 2003
If the pump ran dry, it may well need replacing. I expect you topped up fluid after finding the leak, if so, and pump makes a lot of noise, then that would confirm. ( did you bleed system, turning steering from lock to lock to get air out)
Pretty straight forward, swap pump and bleed system
ajlsl600
france
Either cavitating due to air or pump goosed.. if you change pump.be careful to check for debris in rack ..flush the system
