Dan73
- Dec 23, 2022
- C 300 Sports Premium
Have had a number of issues with the app recently not synchronising on status and showing the following message; Power Supply On Remote control deactivated.
It took me a few days to work out what is causing this error and how to fix it. I’ve read some reviewers about same or similar issues and nothing was clear on how to fix it.
However I managed to fix this issue with the app by simply going into the app menu - the 3 bars top left corner then under your name select comfort services then manage services. You’ll then have the option to deactivate / activate remote services. Turn off remote services then back on again noting it takes a few seconds in between deactivation and activation.
Once you have deactivated and then deactivated the remote services the issue should be solved and no more Power Supply On error etc.
I trust this helps.
Thanks.
Dan
I trust this helps.
Thanks.
Dan
