Basdeosing Persand
- Oct 21, 2020
- C350e/2016/2000 c.c
Hi Martin, I got a mercedes c350e too, year 2016 and i got problem with my airmatic suspension last week. while driving i got the display "stop vehicle too low" , i stopped my car and i was able to raise the vehicle. But the next day i found my vehicle sitting down completely. The vehicle did not rise at all when i pressed the raise button, I could hear the compressor working so i try to look for air leak. I checked the pressure from the compressor and i found it too low as i was able to stop it with my finger. Tested it with a gauge and found the pressure to be 1.5 bar. I removed the compressor and found the discharge solenoid faulty as it was not clicking when i applied a 12 V dc current. the problem was that the valve in the plunger of the solenoid was stuck. with the help of a pin I pushed the ball ( seem like one as it is very small) in the valve and could then feel it having a springing motion. i tested it again with a 12 DC volt and could hear it clicking. tested the pressure again and could it it rising fast to 10 bar. Fitted the compressor and vehicle restored back into service. See if this might help you
