Hello. I wondered if anyone had any good fixes for a vacuum problem on the tailgate of a C180 estate 97plate. It appears that the vacuum pump is not powering enough to lock the boot once it has been opened and the handle is engaged. Is this simply a case of changing the vacuum pump? I had changed the vacuum pump once but there was a kink in the tube. Now I've straightened out the kink I'm hoping that replacing the vacuum pump is enough? I've had the lock off and watched the mechanism as I lock and unlock the car. Is there another part that may be in need of looking at?
