John Gallen
Car is very slow to start requires prolonged turning over, eventually starts if battery does not go flat first. Seems worse since it has become cold.
Changed glow plugs ? not much different.
Battery ok and holding charge.
No warning lights.
Runs ok when started.
Starts ok when warm.
No obvious fuel leaks or smell of diesel.
I believe there is a glow plug timing relay, cannot locate it at present, and it is also possible to test circuit.
Questions.
Anything I have missed?
Where is glow plug timer relay?
What should voltage be at glow plugs, suspect 12 volts
Can relay be tested, cleaned, or adjusted?
Any assistance advice much appreciated.
Regards
John
No warning lights.
Questions.
Regards
John
