Conor
- Jan 22, 2019
- Location
- London, UK
- 2010 S212 350 CGI // 2004 R230 500
Hello,
So this morning I set out to replace the rear suspension air bags.
I ran into a problem. Ideally I wanted to jack up from the centre rear and place the axle stands under both side/rear jack points. No chance, as my jack wouldn't reach far enough to jack up via the differential.
I then then jacked up each side and found another point near the suspension that was solid and put the stand there. Upon repeating on the other side, I noted that instead of the jack rolling inwards to accommodate the rising lift, the car towards me while jacking up (sideways move). I'm not sure if that was because of the physics of lifting both sides independently or if the ground was sloping laterally, I don't think it was.
Anyway, instead of doing something risky I stopped and packed everything up and decided to do a little more research.
Wondering what I should do now.
I guess the solution for centre jacking is a more appropriate jack. But if I want to work on each side independently, where is the best place to put the axle stand?
The car is a pre-facelift s212 E 350.
