Problems with Audio 10 MF2199
L
learningtofly
I've just swapped out the existing radio cassette that came with the car (a 2002 CLK200) for an Alpine Audio 10 MF2199 bought in absolutely perfect condition for £50! The player is working as it should in all respects but I have a couple of questions...
Firstly, it doesn't turn itself off when I remove the ignition key. The manual says that it should - anyone know why this might be?
Secondly, it doesn't appear to light up when its switched on. I'm uncertain as to whether it only lights in a visible way in dark conditions but perhaps someone could tell me.
One other thing - the keys that I bought/used to remove the original player worked, but now won't come out of the removed machine. Is there a way to remove them without causing damage or are they stuck in there forever??
Many thanks in advance.
The main wiring plug is in correct I think.'
The car and the radio need a live supply for the memory back up, ii needs switched live from the key to run it.
There is a separate wire for the lighting.
There are adapters around for making it a plug and play for the wiring harness.
To remove the keys from the old unit just lift the spring levers, one each side, and pull the key out
L
learningtofly
Ah... thanks, but I suspect this has suddenly become beyond my capabilities! I researched the model I needed quite carefully, and it was allegedly "plug & play" and a "two minute job". Aside from that, for the life of me I can't get the release keys out of the old unit and I don't want to end up snapping them off (the spring levers are encased and not at all east to get to).
I guess it's a trip to the auto-electrician for me, then :Oops:
Re the keys,, you should see in each side a hole or slot where you can lift the spring clip, or can you put a photo up of one side of the unit..
Do have a word with another ICE shop re the wiring
L
learningtofly
Having decided that this is best left alone (by me, that is :neutral:), can anyone recommend a suitable sparks/dealer close to Borehamwood and give me a rough idea of how much it's likely to cost?
Thanks again.
There is a big one in Apsley near Hemel Hempstead that is on the main A41.
L
learningtofly
Thanks Malcolm. I've now spoken to their audio technician who's going to po round one day next week and sort everything out for me.
