Problems with gearbox
Spud990
E300 TD 1998 om606
Hi I’m new to all this
I have a 98 e300td
I lose drive and my rev counter when a bas ars light comes on but only seems to come on when the car is warm. Any ideas what it might be as I’m very stumped. Any help at all would be much appreciate
thanks
C200d/2015/2.2
I have a 98 e300td
thanks
Sounds like the crank position sensor.
Spud990
E300 TD 1998 om606
Ok thank you I’ll replace that and see if it’s that on the om606 engine
umblecumbuz
Wales and Gozo
Hold hard, partner!
Faulty CPS usually cuts engine completely, or engine fails to re-start after it is turned off while warm - it does not normally drop into limp mode and affect Abs(which seems to be what our OP is describing).
Before just swapping bits, get the car fault-tested. This will give you a more accurate diagnosis. There could be several more likely reasons for your symptoms.
Spud990
E300 TD 1998 om606
It was the crank sensor. As that is the only part of the engine now that tells the gear box it’s running. I have put a mechanical pump on it. Thank you all for your help tho
mioba
Nottingham and Köln
Just out of interest, why a mechanical pump and for what, are you circumventing the issue as opposed to solving it.
Spud990
E300 TD 1998 om606
I have a mechanic pump on it as the engine is going to be removed and place in a dodge once I have it running 300-350bhp.
umblecumbuz
Wales and Gozo
Thanks for coming back with a result. That's taught me something!
