Problems with soft-top
Status
Not open for further replies.
AAPete
Kent
Anyone else had problems with the soft-top on a CLK failing to open and shut?
The car is 2002 so it cannot be wear and tear...
springer
Portland Oregon
same problem & resolution
We had the same problem on our 04. After replacement of the front rams they found that the real problem was simply the plastic lines, there was a restriction in the line. They replaced the line and all seems well at this time. The work was done about 3 weeks ago, and my wife has been putting the top up and town daily since then.
Good Luck
A
AAPete
Kent
Thanks for taking the time to reply...
Took it on to the Mercedes dealer there was a hook missing that holds the small plastic shelf in the boot up, this I believe was the problem as the microswitch was not connecting with the weight of the roof in the boots, new hook fitted and so far so good..
I may put mine up 6 times a day due to our weather!! :?
springer
Portland Oregon
You sound as bad as I am about having the top down. After seeing what is going on over there on our news, you also need water wings and a rudder. My wife and I lived in Richmond upon Thames at the Richmond Bridge. We were there for about 6 months during 90/91. I remember one storm we had with winds in excess of 90 miles per hour. That winter was a wild one. I hope you have good flood insurance.
Status
