Questions:
where do you get your ATF at a reasonable price?
how to fix abrupt "lift off" from a standing start?
where is the diagnostic socket on this car (expected circular one but can't see it)?
I'm new to the forum and been lurking/reading - great info on here!
Local Merc dealer wants £8-99 per litre and the local independent wants £5-99 per litre.
Where do you guys get your fluid, what brand/type do you use and how much do you pay?
Car is a W124 E320 Coupe with the 4-speed auto (S & E switch) and due for the 36,000 mile auto oil and filter change (its done 108,000 miles total).
re the "lift off", the car is difficult to start off from a standstill without causing whiplash - Throttle seems to stick and then whoosh!
I plan to clean up and then adjust the (filthy) throttle linkage and lube the accelerator pedal and cable - anything else this might be? (changes on the move are fine and the box is quick into first and reverse from park).
Previous owner was ill so the car sat still for a year....changed all the rest of the fluids/plugs/air filter/fuel filter/cleaned up the brakes and ran some injector cleaner through and all seems fine - passed MOT with no issues.
Not bad for £3,000...
Thanks,
Steve
Thanks,
Steve
